Does anyone know what time it is?
ctpaddler2000
I tried to RTFM, but I still can't figure out how to set the clock on my 2012 RS. All I ended up doing was changing the display from MPH to KPH.
If the clock on the 2011 is anything like the clock on the 2009 GS don't bother. I set my clock and it will only display in 24hr format and will be15 minutes plus by the next day. :mad: If BRP can't get a clock that works it explains a lot about other programming failures.
Well I'm not sure about the RS, but with the RTs, you just hit the "Mode" button until you get to the preferences screen:
Scroll down to where you would adjust the time...
Arrow over to the right
Make your changes
I'd be guessing that the RS is pretty similar to this...
Good Luck!
Now go enjoy Hamma' time! :roflblack:
heres how
Press and release the mode button until the time is displayed. (Either button, handle bar or dash)
Press and hold the mode button until the display alternates between 12 and 24.
Press and release the mode button while 12 is displayed and the display will alternate between "A" and "P"
Press and release the mode button while the correct part of the day is displayed A for AM or P for PM. The hour will begin to flash.
Press and release the set button (on the dash) to choose the correct hour. Press and release the mode button and the minute display will flash.
Press and release the set button (on the dash) to choose the correct minute. Press and release the mode button.
Done
Done
:agree: And on my GS it gains about 5 Minutes every 30 days.
Done
Thanks. I did RTFM first. It just took staring at the directions and the display as few more times for it to make sense. I should have had my 18 year old daughter try before posting.
