Dochands TPMS
Okay, can anyone tell me, if you leave the rubber valve stems on with a tire pressure monitor system that they will eventually fatigue and break?
With or without the TPMS, rubber stems deteriorate and crack over time. I've had some last as long as ten years (riding lawn mowers) and others, two years.
No I didn't. Just straight on the existing stems. Never thought about the issue but I guess it should be a concern.
Tiregard allows you to set thresholds and pressures for each sensor. It also allows you to remotely monitor for all thats worth. lol
My Spyder has a TPMS as standard equipment.
It was in the tool kit that came with the Spyder.;)
Good point. :ani29: No matter how you do it, I don't think enough pre-ride inspection is given to tires. They take alot of abuse. I inspect mine often just so I know what is going on there (including lugs). It's all anyone would need is to have a tire fail. I think as I go on I am doing more in terms of pre-ride checks. 14 has a few miles on her now! :doorag:
