Does the 2014 Spyder Rt limited have an enriching circuit for starting ? :dontknow:
Taking a guess on this, but I think all modern gas engines have this. ... I know on my 14 RT, initially it runs at 1200 RPM's then after about one minute it settles down to 900 ..... JMHO .... Mike :thumbup:
:agree: My 2014 is exactly like Mike's. 1,200 at startup and 900 in 1 minute or less; just like most new cars. :thumbup:
Yes only our VTwins idle a little higher. 1500-1600 at first then settle down to 1300-1400.is this the same for a 2011 ???
But that doesn't mean it has an enriching circuit.
Are you saying even though the enriching process is software (firmware is simply software that doesn't disappear when power is removed) it is still referred to as an enriching circuit by the engine industry? I see circuit as meaning a physical feature, not a software path. Everything I've found in a Google search has focused on circuit being applied to a physical configuration meaning a separate fuel path beginning with carburetors. I don't recall ever seeing the word circuit applied to a software path such as a DO loop.Yes there is -- the enriching circuit is in the ECM firmware.
If the word circuit has been expanded by the industry to include the portion of the algorithm that enriches the fuel at startup, then I'll agree the Rotax has an enrichment circuit. In that case I don't know why the OP even asked the question because every ECM for many years has included a fuel enriching circuit in its algorithm. But to my way of thinking the fuel enrichment process should be referred to as a fuel enrichment mode since it is just one of many specific groups of parameters that control engine operation.
