EdMat
Well-known member
It’s not a Bushtec. Only had it two weeks and put about 2,000 miles on it and 3 people have asked me that question.
It’s a Discovery by The USA Trailer Store in Greenville, SC. Picked up from them on an east coast swing. Pulls great. Shares a similar if not identical suspension with the Bushtec. Very little movement of items in the trailer. Carpeted on the inside, top and bottom. Has a luggage rack, not sure if I will need it with all the room inside, but never say never.
The folks were great to deal with, sent all the paperwork in the mail to me and I was able to get the title and the tag before I even picked it up. They even mounted the tag for me.
Comes with a small hand operated air pump to adjust the shocks. That took a couple of tries to get comfortable with, but with the small amount of air needed for changes you don’t want to use any type of air compressor. 3 to 5 strokes compensate for a pretty good weight change.
The only downside I have seen is the gelcoat finish. That part is not up to Bushtec standards, but they mention that on their website. Not that it’s bad, just not perfect. If I were to leave it black, a good claybar job and a couple of coats of good wax and I would be happy. It will get painted to match the bike…...end of problem.
The taillights are slightly dim but the light bar mounted in the spoiler is plenty bright. Brake lights are fine.
The only other negative I have found is I will have to raise my rear facing dashcam because now it can’t see enough to be useful mounted down by the RTL’s tag.
Would I buy it again, yes. At $2,999 I think it’s a very good buy.
