Disappointing maiden voyage on new to us Spyder
Wrongway
POST #47 ON PAGE 2 HAS THE RESULTS OF MY SPYDERS PROBLEMS.
Sorry about the length of this post but I'll keep it as short as possible
BACKGROUND:
We got rid of our 2011 Spyder RT in April because of mechanical issues. To get rid of it we traded it on a 2007 Goldwing because we've had goldwings in the past.
The 2007 Wing was great but we both really really missed 3 wheels.
Sold the Wing private and picked up a 2014 Spyder RT Limited in a private sale. Bike was taken to a reputable Spyder Dealer for a check over and safety prior to purchase.
Picked up the Spyder 9 days ago and during the 9 days rode it 400 trouble free miles.
Today was our day for a 300 mile return trip to our daughters.
Here are the codes that we got not once but several times during our ride:
C006C C003A P2159 P081E P0000
Before going into limp mode with the engine light, abs light and ??????? The bike surged once like there was a fuel blockage and then ran fine for about 5 miles. This repeated itself about 4 times and the the limp mode etc came on.
3 days ago I put a can of seafoam in the bike and filled the tank with Shell 91 octaine and rode it about 100 miles since then prior to today. My first thought was that the seafoam had possibly broken some deposits loose and the bike wasn't getting enough fuel.
Anyway, when the limp mode came on I pulled over immediately and shut the bike off and let it sit for 10 minutes. Fired it back up and engine light etc were still on. I started to proceed and the lights went off and everything seemed fine. Full power was back etc.
This repeated itselt about 4 times during the 300 mile ride.
When we got home, I went out alone and filled the bike up with regular fuel. After about 15 miles the bike went into limp mode and started to downshift all the way to first gear by itself.
Pulled over, shut off for 5 minutes. Start up and proceed and lights went out and bike ran great. This repeated itself 4 times during a 40 mile ride.
I'll take it to the dealer in the morning but man oh man is this ever discouraging. Here's a picture of the dash showing the lights. The engine light was also on so don't know why it's not in the picture.
Sorry to hear about your troubles. Keep us posted what your dealer/mechanic says. Inquiring minds want to know...
Check your wheel speed sensors. One of those codes is for wheel speed sensor and will cause the symptoms you described. Does your bike have a car tire on it? What size if it does?
Lets see....
Bummer...From the codes there seems to be an issue with the rear wheel sensors. Did they do any work back there..? Brakes, tire ..? The other is the clutch make sure you have the right oil and proper level. The last one means nothing. Do let us know what they find. .:thumbup:
Looked at fuse boxes....WOW
Thanks to everyone for your replies. First thing I did the second time I pulled over was to make sure the battery cables were tight. They were. Rear tire is not new and it's a kenda.
When it was in for the safety inspection they also did an oil change and replaced part #278003071 control gear motor and under the price it says warranty. Probable a TSB.
Anyway, I went out to check the fuses. When I opened the left side fuse box cover (the left side when you're sitting on the bike), there was a lot of liquid inside the cover. The colour was like a robins egg blue and had no taste of coolant or battery acid. All of the fuses were wet so at least the dealer will have a starting point.
Anybody have any idea what the liquid could be?
thanks
Greg
Battery connections may be tight but corrosion between the posts and clamps will create problems. And, speaking from my two-wheel experience, don't forget the negative cable connection to the Spyder chassis.
Good points. Thanks, I'll make sure the dealer checks those too.
I think what scares me the most is the liquid in the fuse box. Who knows where that came from or how long it's been in there.
I remember that awhile back there were one or two threads on the issue of water in the fuse boxes. You might want to do a search on that topic.
Thanks. I did a search and found a guy with a 2013 RT with water getting into the right fuse box.
The dealer replaced it under warranty and the day the guy picked it up there was a rain shower and guess what? YEP, water in the right fuse box.
They guy never did give us the end of the story unfortunately.
After reading his post, although I haven't ridden in the rain, the bike did get caught sitting outside during a 1 hour severe downpour last week. After that I rode about 200 miles until the problems started yesterday.
My only thought is that seafoam may be a problem. It is not needed if you use proper fuel.
I was wondering the same thing. I've been using seafoam in my cars and motorcycles for 15 years with nothing but positive results but who knows.
I'm 99% sure it's because water got into the left side fuse box.
Off to the dealer this morning.
Run the VIN through BRP's website. I seem to remember there being a recall or a TSB for water in the fuse boxes. I also seen a posting on Facebook I think from James Thorne about the seals going bad on the fuse block cover over time and letting water in. I have a feeling the liquid in the fuse box is the culprit.
thanks for that. I'll make sure the dealer checks
BATTERY
I'M WITH THE BATTERY GUYS ON THIS ONE......
my RS started giving me codes up the ying-yang.... pull the Tuperware off, and began to test every single electrical connection on the bike.... I SHOULD HAVE STARED @ the battery... the connections (both) were only hand tight, and the cables could be moved very easily.... tightened both down after applying a little PERMATEX DIE-ELECTRIC grease... ZERO issues after that.... when i bought my F3, that was one of the 1st things i did to it and have had ZERO issues related to codes since... you also may want to have that battery tested to see if it has a faulty cell or two.....
Dan P
SPYD3R
Sounds like water in the fuse box. The liquid was colored due to the many materials in the box that have corroded. If its gone far enough to be causing this sort of electrical gremlins, you will at a minimum need a new fuse box and likely a wiring harness. This is not good news. Sure hope you have a warranty.
