Digital speedometer gauge
bubbie
Here's a question I haven't seen before. All my digital gauges on my 2015 F3S are set correctly. The date, time, etc. But today when I went to fill up with gas, it changed from MPH and F* to KPH and C*.
I got it back to F* but it won't go back to MPH. Anyone have this problem and what did you do to fix it? I've held the "set button" and the up arrow like it says in the owners manual, but it won't change!
Did this occur on it's own ???? …. Is it possible you hit the MODE button too many times ???? …. Mike :ohyea:
My ST did same thing few years back (before F3), also changed my radio & rpm display from enabled to disabled & went to trailer mode. Thankfully noticed it at a gas stop & was able to get it back normal. Was fixed with a dash/buds update.
Blue Knight: All I did was hit the reset on the trip-meter. It had happened at the last fill-up also, but then went back to normal with the "set" and up arrow. I'm thinking maybe I should disconnect the battery and see if that resets it.
Bfromla: If the battery disconnect doesn't work, I'll probably have to have a buds reset also.
Thanks everyone! Ron pressed the set button and then instead of just holding the down arrow he kept hitting it and finally it changed back. Now if it will only stay at MPH I'll be happy. Last choice will be just use my Garmin to see my MPH.
