Dealer says Rain triggered Limp Mode & VSS Fault? Is this true?
Two2Three
So today I was on the interstate, in the rain for about 100 miles on I-35. Temp was about 70 degrees, light but steady rain shower. I did have the heated grips on low because I only had mesh gloves and they were soaked and a little cool. Otherwise, I was cruising along just fine, enjoying the vivid wet leaves on the trees.
About 90 miles in, the cruise control suddenly shut off, and wouldn't re-engage.
Then suddenly (first time for me) the "Limp Home Mode" light came on, along with an idiot light that I couldn't quite make out in the rain. Maybe wheels with a little lightning bolt? I'd recogize it if I saw it again.
I was still doing 70, and was passing a big tractor-trailer when it went into Limp mode (yay) but was able to slow down, move behind him and off the road. Shut it down, waited a minute, and started it up again, and it got me the rest of the way home. The cruise control still wouldn't work though, but it did work again much later after I'd stopped for gas for several minutes.
After I got home I called the dealer, who basically said "if it's working now, there's nothing we can do". And also essentially told me riding in the rain is the issue. That it messes up the electrical "stuff".
WHAT? I'm about to head off alone for South Dakota, and you tell me riding in the rain is a problem? Seriously? :shocked: I'm thinking of cancelling my trip and I'll only take long trips with at least one other rider if a light rain can shut down the bike. :sour:
Is this true? Don't ride a spyder in the rain?
Of course you can ride a Spyder in the rain. This is a classic example of what happens if your brake light switch is activated without actually using the brakes. So, you were wet and cold. Could you have been accidentally contacting and slightly depressing the brake pedal without realizing it? Plus, you have a 2022 RT. Have you checked it for the recall on the switch?
I did get the brake light switch recall done.
I don't think I was touching the brake pedal, because I've been warned about that from people who had it happen.
I was amazed when the service tech implied that riding in the rain caused the problems. Hence my question and concern. :)
I rode my F3 through the afternoon downpours for 4 days straight while I did my tour of the cherohala, dragon, moonshiners, and brp back home.
Had to bail out of the BRP after going through heavy thunderstorms on mount pisgah when rocks and rain started coming in the roadway.
even had a f350 coming the opposite way who was so kind enough to go right for a large piece of flooded out road so he could drench me.
But luckily the only issue with water was my show chrome turn signal on the right side lost one led prematurely in cold weather , and I think I can also attribute some moisture causing a premature failure from that trip of my signature light when I took it out in 14 degree weather and it failed on one side..
Rain, even heavy rain, should not be a problem. The brake light switch would be my first answer as it has been with others. That could also explain the link to the cruise control. Did they pull codes to see what the computer said?
No, they weren't interested in me even bringing it in. Just said if it's running fine now, there's nothing to look at.
I need a new dealer.
I rode from Washington D.C. to Calif. first part of June on I-80. I had rain, hail, or both for part of every day with no problems. On the trip to D.C. the guy behind me noted that my brake light was on for a while. I figured out that I had my foot resting against the brake pedal shaft. After that, I made sure my foot was not in contact with it and no more issues.
Yes you do. And now the entire world knows that your service tech is full of crap.
First - props to you for getting the recall done.
Second - here's a link to the actual recall bulletin. The 2022 gets the new, curly-q helper spring. If able, you could crawl under there, to check their workmanship, and make sure that it has been installed correctly, especially where it hooks to the main spring. Refer to the RT picture on page 5.
https://static.nhtsa.gov/odi/rcl/2023/RCSB-23V175-2373.pdf
Something as simple as a new pair of riding boots can cause a rider to inadvertently contact the brake pedal enough to trigger the VSS fault. When you're cold, wet, and miserable, no telling what can happen.
Go on your trip. Worry less. Be safe out there.
Here is what they were not interested in.
Decent Customer Service
Doing the right thing
Your safety
Your satisfaction
Your loyalty
I could add a few more lines. But I'd say you get the picture.
OK my take on this after reading all the other answers ..... my first reaction was :gaah: the dealer ..... That icon you saw was the VSS warning that the Spyder had Exceeded the parameters of the computer ( and YES it was logged in and Yes it could be retrieved ) .... could the Brake switch be part of the problem Yes again ..... But I am surprised you could drive at 70 mph on a wet surface .....here's the thing about WET surfaces .... THEY ARN'T ALL THE SAME AMOUNT OF " SLIPPERINESS ".... From what I learned from my " accident investigator courses " during wet weather different types of rad surfaces will react differently to water .... and there will be spots that are a lot more slippery than others because of various types of contamination ie. oil, diesel fuel, gas, antifreeze etc. .... Real life example - me driving in a downpour & have to stop at a toll booth, after paying I applied throttle & just spun the rear tire, I let off the gas gained a bit of traction and just barely applied throttle ( while the A-hole behind me was blasting thier horn :yikes: ) .... finally got going and slowly drove into traffic. Is this what happened to you ???? .... can't say for sure but it could have .... Mike :thumbup:
Good catch. At 70 mph the OP may have had some rear wheel spin. Though I would think he might have noticed his RPM increasing with no matching increase in speed. That could very well have set the VSS off and disengaged the cruise control. Though it would not explain why the cruise control refused to re-set until much later.
Would be telling dealer interested in knowing what was recorded (Buds)just to confirm what the issue actually was & if is resolved, not just inactive.
I honestly didn’t notice any lack of traction or slip while riding. But I can see how maybe the computer noticed something I did not. I also don’t think I was against the brake. My hands were chilly but the rest of me was perfectly comfortable. I was relaxed and warm in my riding gear and rain suit. But it sounds like that brake pedal must be crazy sensitive. Seems like a big design flaw if hitting the side can cause that much chaos.
I’ll have a look at that bulletin. I can run it up on my Big Blue and get under there easily enough.
I do appreciate everyone’s replies. The weather forecast for Deadwood for the 3W rally week looks like rain every single day, so it may not even be worth going. But that’s why the dealers comment about rainy weather sort of freaked me out!
I have had my 2wd silverado spin the back wheels while doing 75 with the cruise control on going uphill on a wet road.
I don't use cruise control anymore in the rain after experiencing that.
I don't know about more modern cars but I thought there was a warning or bulletin out about using cruise control on wet surfaces at one time an all vehicles.
Well, they tell you in the book not to use your cruise in slippery conditions anyway!!:lecturef_smilie:
You're right, a VSS activation in those conditions would be normal and expected. But, that will activate, correct the situation, and then clear. A Limp Home Mode is not part of a normal VSS activation. And as Ron pointed out, nor would being locked out of cruise control until later, either. But the nugget here, of course, is to refrain from using cruise control in the rain.
Yes you need a new dealer. He didn't even offer to check it out for you! :lecturef_smilie: Did you buy it there? AND, we need to know who this dealer is! nojoke Tom :spyder:
I know I know. And I did actually think about that when the rain started. I kept it off for a long time. I didn’t start using it until the rain was really nearly done. I made sure I wasn’t seeing any standing water or anything anywhere. But if that was the problem I certainly won’t use it unless the road is bone dry in the future.
Yes this was the dealer where I bought it.
