Dead Spyder and parking brake
Buckeye Bleau
I had an interesting experience this morning. I pulled up to the fuel pumps, filled up, turned the key, the computers booted up, dash is normal.
Went to start the byke and nothing, screen went black, nothing works.
After irritating others that wanted to use the pump that I am now blocking, I went to the battery and found the positive terminal was loose, I tightened it and away we went.
Here is the question, is there a way to release the parking brake in a situation like that so that you can push the byke out of the way? Example total battery failure, then what?
Joe
A simple way no. At least that I can think of.
Hook up booster cables or booster pack would be the simplest. I carry a booster pack.
Checking the battery connections is a maintenance item.
