2011RS Problem starting when key is turned on dash doesnt light up and show the check function they go through.Occasionally retryed and every thing works. though the display is not working i can start the bike then quite often the display will work some times with the engine managment symbol lit. turn bike off again and everthing works perfectly . their are no codes coming up. when not working correctly no horn or indicators but hazards work. Has new battery . check connections have removed and checked all fuses and relays and cleaned all terminal to
Interested to hear from some one that might have had a similar problem...
Thanks Peter
Thanks Peter
