Cutting bars no big deal! Loose NO WAY!
Magic Man
Registered User
We have had some people ask about the "cutting of the stock bars" when installing our riser kit. We have also seen some of those "experts on everything" type people trying to "throw stones" at this design in other places.
So, here's the skinny straight from the guy who designed them.
Yes, you cut the stock handle bars when installing the NMN riser kit. However, as a replacement set of stock bars is easily purchased, and for a very reasonable price, (since they are nothing but standard steel bars under the cover). This is not a huge or irreversible thing to do to your Spyder.
I have seen many other mods out there that have you drilling holes or doing other things to other more expensive parts to install those mods, and people line up to do them as well.
The relatively low cost to buy a new set of "stock bars" is nothing to be "afraid" of should you wish to revert to a "stock" set up someday. But I'm not sure why you'd want to anyway? :dontknow:
Other riser kits out there have you removing the stock bars to install those kits anyway, and in as much if you wish to revert to "stock" with that set up you will have to re-install a set of "stock bars" back on your Spyder to do so with that set up as well. With the labor to revert to "stock" being the same in ether case.
However, with no need to go through that labor the first time with our set up, and the cost savings of our kit to start with. This labor and cost savings will allow for purchase of a set of "stock" replacement bars at a later date. So, you are no further behind in any case.
Another cool thing about this design is you can install them without cutting your bars to try!
You can install the risers and swap over the controls and leave the stock bars alone and even go for a ride to see if things are as you wish. Then once you have tried them, then cut the bars as the stock bars will not interfeer with the proper operation of this set up for you to try and ride. The only real reason they are cut is for aesthetics so you don't have 8 inches of unused bar sticking out below your new bars.
Some people have asked about the lower clamp moving on the stock bars....
This type of split half moon clamping set up onto the stock bars is how handle bars are clamped on motorcycles in the first place, and is how snowmobile racers that use huge 12 inch risers over some of the worst conditions you could ever imagine hold the bars in place as well.
This style clamp when tight does not move! You can be sure the bumps and jolts these racers go through is 10 times worse than anything a Spyder will ever see. This is also how those huge ape hanger type bars Harley's use are clamped into place with all the leverage of plus 20 inch bars and yet they do not move there ether.
The 3 or 4 inch riser we use will never have enough leverage to move these clamps when tight. There just not enough leverage or force to be able to do so.
These bolts when properly tightened down have no more of a chance than the bolts that clamp the half moon clamp which holds the stock bars onto the Spyder in the center do in the first place. So "vibration making these come loose just won't happen any more here than on the stock bar clamp location under your center concole holding the stock bars onto your Spyder have now.
I hope this has helped answer some of your questions about this set up and how and why it works. :thumbup:
MM
When you put it that way, it all makes sense. :) I'm pretty happy with the stock bars with the BRP 1" riser but the mention of the reduced vibration in another post has me thinking about these now. I'll try them out when dltang gets hers and we install them.
Not only did I pre-purchase replacement stock bars...$60, I have raised ATV bars (free), and I even bought 7/8" straight stock for about $5. I had other ideas floating and had parts and pieces made in case MM or others did things differently...or better...or similar...you know what I mean. I was going to raise my bars with money (paid), or sweat. So I have everything I need to raise my bars several ways. It's always best to be prepared to go back to original in case things don't work out. The way I see the MM product, there will be no reason to go back. Unfortunately, that's how we collect spare parts.
Having the first set of 3/4" thick risers and now the 1" thick risers I can say for a fact that the 1" with the solid 7/8" bar acts like a bar end weight but better. After 13,000 miles I'm pretty tuned in to every little thing on the Spyder now and that was one of the first things I noticed. :doorag:
Lamonster...about the same time you first showed the extension bracket, I had fabricated a block...what I didn't see was the offset necessary for the controls. So I made that too. I'm shaping and buffing the blocks today, and installing them this weekend. Doing all this just as I ordered the "real" set....My block is aluminum, and the bars are hollow 7/8" stock, so I'll definately feel that weight difference when MM's arrive.
My hats off to botH Lamonster and MM for making what I will call the "BEST MOD FOR 2008". :thumbup:
I encourage Lamonster to create a poll at the end of the year in which we all can vote on our favorite mods.
To be fair, every secondary market dealer advertised on this site has some great products.
As I wait for my Spyder, I have a whole list of things wanting to get. Hopefully, I will get some initial riding on the Spyder just "as is". Then as winter slows riding, I will start to make my modifications to be ready for my first 1000 mile roadtrip planned for next spring with relatives.
I know for sure that the riser modification will be first on my list.
:2thumbs:
:2thumbs:
I love my highway pegs for the long haul and the cruise control is great too but I got to tell you this is the best mod I've done for the long haul and everyday driving. I have less vibration in the bars. My right shoulder is not acting up now and my right hand is not falling asleep. I have more control when I'm hammering it in the turns and I just feel like this was the one thing that was missing for me to make the ride perfect. I'm very happy with this mod and to me it is the best mod of the year too. :doorag:
After doing 300 miles in VT yesterday, I noticed that if I slide forward as
far as I can my sholders and arms feel better. However my LEGS don't like
it!
I get home and this tread is waiting for me.
So...First thing this morning I ordered the 3" to add to my 1" BRP riser!!!!!!!
:thumbup::thumbup::thumbup:
Thanks MM!
it!
Thanks MM!
Mike
I know just what you mean. I never could everything feeling good all at the same time before myself.
Now it is so much better I can't wait till I spank Lamonster through the twisties in Sturgis! :2thumbs: :joke: :D
MM
Oops, there goes the Throttlemeister.
Nope, I think we should be OK as we had the ends of the bars machined out 2 inches to allow for this.
If any of you with a throttlemeister could be so kind as to measure yours and report back that would be fantastic! That way if this amount we made is not enough I can change the spec no problem.
However I think my calculations allowed for use of Throttlemeisters no problem.
MM
MM
WHEW !!!! :shocked: Soon as I read this thread, I ran out and pulled my Throttlemeister. It measures exactly 2". I would feel better if you had a little more than 2" but I'm sure it will work OK! Couldn't do without my 'meister !!!
Done deal! I just made the call to make the change to a "bit" more than 2 inches to be safe.
Thanks for taking the time to measure for me! :thumbup:
MM
I'm glad our design was corredct to allow all of you to use your Throttlemeisters. :clap:
I know the new more comfortable position will now allow for longer rides where a Throttlemeister will sure come in handy. :thumbup:
MM
I don't seem to have a problem with the original position of the handlebars, although that may be because I hanen't tried the risers yet. I have a real problem with the seat though. I suspect I will have a Russell Day Long on order before long. I have used their seats on a number of bikes in the past, and they have all been outstanding.
