Curvey Girl Valve Stem Info Request
frank3
RT-S PE#0180
Sure some one out there has done this but I can't find the thread on the subject. Would like to replace the valve stem on my rear wheel to have better access. Can someone provide me with the Curvey Girl part number for a replacement valve stem?
Thanks Much
Good to know..!!
looks like a great solution for those who have problems with the valve stem on the rear tire. Think they never considered the size of the rear sprocket...:thumbup:
Since my rear tire is down to the wearbars; this is the perfect time for this thread to pop up for me!
Thanks! :thumbup:
Are you saying this will fit down in the small recessed area on the stock rim in place of the original factory valve stem? The photo on the website shows a large washer and collar assembly that doesn't look like it would fit. Since your post was labeled "right side..." did you mean that this valve stem is what you used for a new location on the right side of the rim?
These valve stems fit in the stock hole in the wheel but end up facing to the right side instead of the left side of the Spyder...
