Cruise won't set
sdcatman
Has anyone experienced trouble with cruise not setting on 2014 rts
it turns on but will not set
this happened to my wifes today I could not find a fuse for it
Anyone have any ideas
Thanks Al
RTS
My RSS is doing the same,the switch that disconnects the cruise when the brake is pressed, it is a warranty part. I will have mine fixed this Thursday, you can pull up on the brake padal and push set cruise at the same time and it usually works.
The cruise control quit working on my 2014 RT also... :shocked: It was doing exactly what yours was... :banghead:
I had it replaced under warranty. :thumbup:
My 2014 RT would stop working every time I took it in for service. After about 100 miles, it would work and not give me any more trouble. I was never able to find out why it would not work, so I figured it had something to do with the bike being plugged into the buds software. I know this is probably wrong, and it was only a guess, but as long as it gets back right, and I have warranty coverage, I don't worry about it.
Have you mentioned this to the servicing technician? :dontknow:
He might have an idea about the cause: if he knows about the problem.
Just a quick visual....multiple switches disengage the cruise, and will also prevent it from setting. Check the clutch switch, and brake switch. make sure all wires are attached, and you can hear the "click". Brake switch clicks twice thru it's travel.
Probably not it, but worth a look just in case. Please post the outcome
I believe it was the brake pedal switch I cleaned it this morning and it worked fine for 225 miles today I will keep you posted
Sent from my XT1254 using Tapatalk
Had the issue on my 14 RT. Did a software update at dealer five mi. All good. Had called brp about he issues just an uldate
