Crapola
zuni
F3 has a three wire system for brake lights, Magic Strobe Brake Light flasher from Custom LED (sold by Custom Dynamics and many others) is a no go. Unless you want your running lights to flash instead. :(
CJ JAX
On my RT I have the Custom Dynamics high mount brake with the Run/Brake Module and the Strobe Unit. So my running/brake lights on the Spyder and the high mount all flash at the same time. I have mine set to flash 4 times then go solid.
Did almost the same on our RT. the high mount and the brake lights flash on braking but I did not set the high mount up to be on with running. Unfortunately I ordered the strobe and started making a harness without thinking to verify that it was a 4 wire system. :banghead:
CJ JAX
