cowtown to the rescue
dabreitbach
Found out my front sprocket is bad.:gaah: Cowtown has one (nobody in my area has one) and they are overniteing to me.:2thumbs:
Thankyou Cowtown
Cowtown is awesome:2thumbs:
Can't believe Leer's in Waterloo didn't have 1 for you.:dontknow:
Glad you are getting one and not surprised where it was in stock.
Jim:thumbup:
Jim:thumbup:
Called Leer's and no joy. Even Rob's performance didn't have one. :dontknow:
For those replacing bad sprockets, check carefully to see that the shaft is not damaged. Any play when the new sprocket is installed means the shaft is damaged, and must also be replaced.
Lol got your back jack!!! Honestly just glad we had it for you. Good luck and let us know if you need anything else. :thumbup:
:2thumbs:
Glad to hear Cowtown had the sprocket in stock, and hope you are back on the road in no time. Are you going to replace the belt as well?
Got the sprocket this morning and installed it. The shaft was fine and no play that I could tell. I also used some 271 loctite on the splines . According to what I found on the internet this will help if there is any play.
Its suppose to take up any slack. An electric motor guy said the same thing. It sure won't hurt anything.
Also the sprocket is a new #. Its the one for the 2011 rss. Checked brps parts site and the old # is not available anymore. It does not have the harmonic damper on it.:2thumbs::dontknow:
Thanks cowtown!
Thanks cowtown!
:congrats: I hope you get great service out of the new sprocket.
