Could disconnecting the positive terminal of the battery for a few days cause any problems?
If you have a Can-Am Spyder of some type look in the operator's guide table of contents for Battery and go to that page and you will find this warning: NOTICE Always disconnect the NEGATIVE (-) cable first to avoid damaging the electrical system of the vehicle.
The reasoning for disconnecting the negative terminal first is to prevent a dead short if you were to bump your wrench into a ground when disconnecting the positive terminal first.
