tonynorwood
I have a 2012 RT Sypder (Limited), with 11K miles on it. I always had maintenance done, as required. I have not had many problems, but what problems I had I feel should not have occurred. Mostly the codes came because I did not know how to ride it (I think). I don't ride it fast, don't ride it much, and am not an aggressive rider. Recently, (sometimes) when I turn a corner, it seems like the power steering stops working. This happens if I am just turning around a corner (slow), but especially, if I starting from a full stop at a stop sign. As I turn left or right, about half way through the turn, I have to really pull/push on the handlebars to get it around the corner (a 90 degree turn). I check this starting the cornering slow, then a little faster, but not fast enough that the Nanny should be involved. Has anyone experienced anything like this? Or, does anyone have any suggestion as to what could be causing this?
