Coolant leaking out of spyder airbox
COOLANT - AIRBOX
:agree:................And ,,,Sorry but I can't see anything in the Pic ........... It doesn't get any larger ........... Mike :thumbup:
These are unrelated component systems... the leak must be originating at another point, and ending up at the aiirbox...
Further investigation of this is needed...
And :welcome:
I'd bet your reservoir tank is cracked, which was common. As your riding it's leaking out of the pressurized tank and the intake is sucking it in.
Sent from my Nexus 6 using Tapatalk
Exactly where I landed, too. Why don't you pull the top off the air box and clean all that stuff up. Check your coolant level, check that plastic tank for a crack, and check that the cap on the tank is on correctly. Since the intake ports are directly behind that tank, it's a high probability it's getting sucked in from there.
Ok, I will review what they advise and report the result ... thank you.
Hi CALAIRC,
I had something similar on my '08 last year. Only I found coolant drops on my garage floor.
I would top up the coolant bottle then find coolant leakage when I would stop somewhere.
Once the coolant leaked to below where the crack was, it would no longer leak coolant.
It turned out to be a non-visible vertical crack in the upper 1/3 of my plastic coolant bottle.
I had it replaced and all is well with the world.
Jerry Baumchen
If you end up needing a new coolant tank let me know... I have a brand new spare I'll make you a deal on....
Little checking..
Three main places to check...
1. The radiator cap..tighten to the second detent
2. Radiator hose clamp.. the only adjustable one on the spyder
3. The resivouir tank..for any cracks
Any of these will blow back to the airbox snorkels...:thumbup:
