eddieshep999
Checking the coolant on the RT is not easy as the Coolant tank is located in the Tupperware and I find its not easy
to see the level
Has anyone come up with a way you could use a dip stick type tool that once the Cap has been removed
(And that's not easy with the amount of space available) you could slide the dip stick in until it reaches the bottom
of the coolant tank and then remove the dip stick to see where the coolant shows up
A bit like the way we have to check the oil
Any dip stick would need to have a level mark to show when the coolant is at the correct level and the dip stick would
need to be flexible or shaped to allow it to go in via the cap and then reach the bottom of the coolant tank
There are many Spyder owners who seem to come up with inventive solutions to problems and maybe someone has managed to address this issue
Thanks
to see the level
Thanks
