Component-sensor part number & location
SportsterDoc
Research continuing...additional input appreciated, especially items 24-26:
1. coolant temperature sensor 278002895 (front, between coolant hose and heat exchanger)
2. pressure and temperature sensor 707000995 (intake)
3. throttle body 420893147 (intake) may include TPS?
4. injector 420874855 (cylinder head)
5. pressure cap 509000180 (top of tank)
6. oxygen sensor 707600872 (exhaust manifold)
7. oil-water heat exchanger 420656698 (front of motor, below tank)
8. crankcase position sensor 420966570 (right front of motor)
9. stator (400 watt) 420296913 (motor rear)
10. starter assembly 420893830 (right side of motor)
11. fuel pump module 548874036 (in fuel tank)
12. transmission lock (parking "brake") cable 420945895
13. right multi-switch and throttle 710005275
14. left multi-switch 710005274
15. ECM 420464024
16. steering position sensor 219800354
17. speed sensors 710005610
18. voltage regulator 710006002
19. starter relay 278003012
20. VCM module 219800437 (right front low)
21. yaw rate sensor 710005658
22. brake switch 710005480
23. oil pressure switch 420856536 (left side of motor)
24. knock sensor _________ referenced under warranty section of owner's manual, but elusive
25. cam position sensor _________ referenced under warranty section of owner's manual, but elusive
26. tip over sensor may be incorporated into ECM???
