Comfort grips
Nico75
Hi all has any one fitted the red thicker grips to Ryker , if so did you struggle to remove the mirrors any tips on fitting the grips regards Nico 75
Assume you are talking about hand grips.......................... Just put some dish soap on the tight places and slip them on.
I have the foam slip-over grips on mine. The mirrors use a wedge style clamp so the best way to remove them is to unscrew the mounting bolt SOME of the way out of the end of the handlebar and then tap the head of the screw into the handlebar like you are banging on a nail. This loosens the wedge clamp inside of the handlebar.
Once its loose you should be able to wiggle/slide the mirror and its clamp out of the end of the handlebar.
Hi Marubis thanks for info on mirror removal I'll try it when my grips arrive BRP (£35 ) wow. Regards Nico 75
