What do these fault codes mean? V0416; C006C; C003A
It's most likely U0416 and not V0416, right?
This relates to your rear speed sensor and the speed signal from it being implausible. Did you do any work back there? Change tires or brakes? Damage/remove the sensor? This thread, link below, even identifies that dirt clogging up the hole that the sensor is mounted in, can affect the signal. Turned out, it wasn't the tires after all.
if you changed the rear tire, or otherwise ran the rear wheel with it up in the air, all you have to do is go ride around for a bit.. (in that thread, you can ignore that whole 3500 RPM, 35 MPH thing. It's nonsense. Just ride around at highway speed.)
In many instances like yours appears to be here, the simplest way to clear the codes is (as discussed in the thread that @Snowbelt Spyder linked earlier/above) just to carefully ride the bike for a little bit. ;)
Generally, if you got those codes simply because you ran the RT with the rear wheel in the air &/or it was a minor issue with the sensors or tone rings etc, it won't take anywhere near as much as 30-40 metres of gentle riding to clear the codes; but sometimes, if the pressure switch or parking brake got involved as well, it might take as much as 100-200 metres of riding with a few gentle left to right swerves and back again thrown in! :rolleyes:
Basically, if you've fixed whatever caused the codes and the issue that may have been alerting you to a potential problem or just confusion in the messages the computers were getting (ie. it was not a Major Safety Concern and it's gone now anyway!) so that whatever is no longer happening, then simply riding the trike carefully for a bit will do the job. If it doesn't, then that probably means there's still something wrong somewhere! 😣
Ps: This entire Forum is dedicated to Can Am Spyders & Rykers in all their model/variations including the Specials, the Canyons, Sports, and the Rally versions; so rather than just calling your trike simply a 'can am spyder', even if you do give us the year, and still leaving us to take a wild guess as to what the truly 'important to know' model might be, it's waaaaay more helpful if you tell us what year and model of 'Can Am Spyder' (or Ryker) you might have, like an RT, an F3, maybe a Canyon, or a Ryker. ;)
You can pretty much always leave the 'Can Am' bit out, cos we don't often refer to cars manufacturers like Porsche or Alfa Romeo here on this SpyderLovers Forum; and you can even leave the whole 'Can Am Spyder' bit out entirely, cos that's almost always going to be a given too (unless maybe you're posting in the Off-Topic area) but please do tell us what year your trike is and whether it's an RT, an F3, a Canyon, or a Ryker - That, along with the year and occasionally, the engine size, is the info we generally need to know to properly answer any questions about your particular trike, which is why the following Sticky asks members to include that info in their Sig Line:
It's pretty easy to put that year and model info into your sig line, the steps are detailed in the thread above at post #129 by @Mikey - the earlier methods mentioned were for the old platform, so they won't help any more. ;)
Got error code V0416 - what is it? Also won't down shift automatically, what could be wrong?
Mod Edit: Merged into existing thread & put both into a more appropriate Forum section...
I only have Spyder Codes info for the older (pre-2018) models, and since you haven't told us what year & model of Spyder you're talking about, I can only assume from your post back in May 2015 that it's a 2014 RT... (Which is why I moved this thread here. ;)) If that is the case, that particular code is not shown on any of my Spyder Code listings. 😣
Not that it helps much, but are you sure it's a 'V' and not a 'U'?? Error Code 'U0416' is a fairly common automotive (non Spyder/BUDS) code for a VSS error, but I really don't know if that applies here... :unsure: The later models may have that code in their onboard programming &/or in their diagnostics, in which case someone with those models or access to that generation of those codes may be able to help more, but I cannot. Sorry. :(
Maybe to help us help you, you could follow the directions in this thread:
Page 7 of the thread, post #129, and ADD your Spyder model and year info to your sig line?? That way, it will appear on every post you make, so readers will know at a glance which Spyder you're asking about. ;)
It's like we said before in your earlier thread on this Russell. One to which you never gave an update on. (Help us to help you!) First off, it's U0416, and not V0416. And it's a general code for "Vehicle Speed Not Plausible". So, it's still relating to your speed sensors. Do you still have the other two codes? If it's not the rear sensor, although I suspect it is, then check the other two. Damaged wires? Loose electrical connector? Loose fastener? Dirt surrounding the sensor or blocking the hole? Clean up around the sensors.
Or, one could have simply failed. You'll need to put the machine on BUDS to find out which one.
