Code P0127
Pikester
Hopped on my Spyder today and check engine was flashing. I pulled a code, which was P0127. Does anybody know what this means? The temperature was reading 127 when I got on the bike. It was hot today, but not that hot!!
Thanks,
Pikester
P0127 - Intake Air Temperature Too High
Possible causes
- Intake air temperature sensor harness is open or shorted
- Intake air temperature sensor electrical circuit poor connection
- Faulty Intake air temperature sensor
You are right. I went out a little while ago and it was back to normal. Could the 129 degree temp have triggered that code?
Yep, That's the way it works, A lot of heat gets trapped under that plastic, Especially with the extreme hot weather out your way lately.
Would it help to get rid of some of the heat if I remove the drip pan that Lamont removed to make his oil changes easier?
I'll defer that question to someone else i was lucky i guess,? I never had a heat problem on my GS [08]:dontknow:
