Clutch not engaging after fluid loss - any thoughts?
Remdog
I have a 2012 Spyder RT SM5 manual transmission. Before I put it up for winter the clutch was feeling different. When I started it for this riding season the clutch would not engage. I check the fluid reservoir and it was dry. I just refilled the reservoir and bled the line. Clutch still will not engage. Thoughts?
Why was the reservoir dry? The fluid had to go somewhere. Is there a leak at the slave cylinder? First place I would check is the slave cylinder seals. I have no experience with the RT, but most motorcycle hydraulic clutch failures I have repaired have been do to slave cylinder issues, usually seals.
:agree: Quite a few of the early Spyders here in Oz have done their Master &/or Slave Cylinder seals, giving exactly the results you describe... only YOU might not be able to buy a replacement seal kit for these as you would for any other bike! :banghead: . But there are seals that will fit; you just hafta spend the time & effort to find them! If I can track down the details, I'll post them up for you, but don't hold your breath waiting.. ... my memory and filing system just ain't what they used to be! :rolleyes:
