With any luck, the Outlander Bars will do the trick for you! :thumbup:
Still, posting pics isn't really all that hard!!
If you can take/get a picture loaded onto the device you are posting on here, then it's simply a matter of using the '
Reply to Thread' option &/or selecting '
Go Advanced' (down the bottom right of the
Quick Reply text field) and then scrolling down into '
Additional Options' to where it says '
Manage Attachments'. Once you've opened '
Manage Attachments', select where your pic is coming from, open that file/device & select/choose the appropriate image so that its address appears in the '
Choose File' field, then once again going to the bottom right corner, you need to select '
Upload File' - and I can assure you, it's a whole lot harder to type out these instructions than it is to actually
DO the 'post a pic' bit!! :sour:
If your pic &/or its address isn't coming up in the appropriate place, then you've missed a step somewhere, PM me & we'll step thru it; but if it's displaying sideways or upside down, then you probably took it with your camera/device's '
anchor corner' on the wrong side for the software here to handle it!!
You can rotate & save your pic in a photo editor before trying again; but if you are taking pics purely for the Forum, then the pics from most smartphone cameras will work fine if you take them in Portrait mode - if you need to go to landscape mode to fit it all in/just because, almost all of pics from smartphone's will work properly here if you rotate the smartphone/camera
ANTI-clockwise into Landscape mode, so that the corner that
WAS top right in Portrait becomes top
LEFT in landscape mode...... got no helpful hints for other digital cameras tho, you'll need to know which corner of the image they use as their anchor point and align the camera so that when uploaded here, that corner ends up in the top left corner!
Over to you! And good luck with the Outlander Bars! :thumbup:
