Firefly
Since many have asked if my vents are 'real' and wanted to know what is under the hood.... here it is....
This is my "cheesy airbox 2.0" prototype.
Been running this one for around 3,000 miles and seems to work very well at keeping the Evoluzione intake noise quiet while bringing in cold air for the intake. Both vents feed cool air into the new airbox-- which is simply 2 parts held together with zip-ties (hey-- I did say CHEESY didn't I).
My main goal was to quiet things down as the Evoluzione intake setup is LOUD! This cut noise down easily 50%-- probably closer to 75%-- I can hear my Hindle again!
Inside the box is the Evoluzione Race intake foam filter/manifold plate.
I used:
3" Fresh Air duct rated up to 400 degrees
2 Stainless steel marine cowl vents
2 Intake Duct Mounting plates
DEI Heat Shield and heat tape.
The entire box was made by using the sticky-back DEI heatshield-- 2 layers stuck to each other. I had leftovers so I used that on the Y panel. This stuff is amazing--- REALLY sticky, fireproof, heat shield.
Still hoping someone will come out with a new airbox setup.. or might go with an Aerocharger setup... but for now this is my current airbox prototype.
Any questions or ideas--- post away.....:thumbup:
I used:
