frank3
RT-S PE#0180
Just a thought but wondering why there couldn't be some acceptable way to check the Spyder oil level, while the engine is cold and has set for some period of time. The reason I'm asking this question is I'm always frustrated with the foam in the oil when checking it as outlined in the owners manual. Perhaps, I'm not waiting long enough after shutting the engine off but at any rate, if you follow the procedure, mine at least, will always read higher than I think it should because of the 1/2 to 1" of foam on top of the oil in the oil tank. Seems to me that checking it on level ground, cold and having set for at least a couple of hours, should be doable. Of course, I'd expect the oil level to be much lower at that point but I'd think it would be predictable. Seems that the same (constant) ammount of oil would drain back into the engine crankcase.
opcorn:Thoughts?
