Does anyone else have trouble seeing the level of your radiator coolant. I thought I had been smelling hot coolant after a ride so I decided to check the coolant level. The problem is I was unable to determine if I had coolant in the tank because of where the tank is located and the color of the coolant. I eventually put a small wire thru the cap to determine fluid level. I did have fluid but still can not see the line of fluid thru the tank.
lmadsen
lmadsen
