Checking Coolant Level
RTman10
9 days into ownership I've got to the page in the handbook about checking the coolant level. So I've opened the front and found the panel to remove. Book says remove rivet. HOW. Do you twist, push, attack with a screwdriver or what. Won't do anything for me.
If it's anything like mine, that's a 'push-pin' rivet that needs the centre 'plug' to be lifted before you can pull the rest of the rivet bit out. :shocked:
They do make special tools to do that if you want, not particularly expensive, & I'm sure someone will oblige with a link in due course, but I don't do it often enough to warrant that & just use an 'O' ring pick to lift the centre push pin via one of the depressions in the side, then use a small flat blade screwdriver to lift the outside/remainder of the rivet. :thumbup:
While you are checking the coolant in the overflow tank, bear in mind it doesn't NEED to be at the MAX level when it's cold, just anywhere at or over the LOW level (which may be a bit hard to see!) If you fill the overflow tank to the MAX level while the coolant/engine is cold, you will likely only dump all that extra out onto the road/into the nooks & crannies in the tupperware where it'll leak out later the next time the engine warms up & leave you with the level back down somewhere near LOW once it cools down next! That's exactly how it should work & is why you only need to check that the level is above the LOW mark whilst everything is cold!! :lecturef_smilie:
Good Luck! :thumbup:
I use a small screwdriver and carefully pry the center up. If you ever need more of these for any reason you can buy a bag of them from Value Accessories, a page sponsor for just a few bucks.
Joe
Once you get that cover off you will find the tank cap is difficult to grip. If you just want to check the level, use a flashlight. If you take it off, make sure you get it back on straight. Happy Father's day.
Managed to get the cover off and as you say not too easy to read but all done and put back together again. Fingers are not all that much injured. Will use a screwdriver next time.
checking coolant level
Joe
Or @ your auto parts place of choice also
instruments of distruction
if I am remembering correct , a 10 m.m. allen { or torx } type wrench , and awww heck now I gotta go look it has me thinking what it really is , { be right back , --- foot steps fading ......... foot steps getting closer , ----} o kay took a look , it is a ratchet , with a 10 m.m. 6 point socket , and also , a torx head t 30 wrench , I have my torx on the end of the 1/4 handle that will fit sockets or other 1/4 drive items .... seems too fit a lot of the things on the spyder { on a 2012 any who}
