On August was going to the dealers to get my right mirror fixed. The top mount was broken by a Michigan pothole. !0 miles from the dealer in Cement City, MI. the check transmission screen appeared. As I was close to the dealer I kept going. I just made it there and that was as far as it would go. They pushed into the service area and noticed the drive belt was shredded. Said the would check it out the following Saturday.
What they found was the bolts holding the front drive pulley had come loose and the spline was worn down. This caused the pulley to wobble and shred the belt. Said it would take two days to fix once the parts come in. They also said they were working on one with the same problem that came in the day before I did. Both are 2013 RTs.
Just wondering if any others with 2013 have had this happen.
