Check trans light at cold start - will warm up fix it?
Hildy
2010 rs check transmission light stays on when starting in cold weather under 40 degrees will it go out if I let it sit and idle for a while?
You should always let it warm before taking off. I start mine and then put my gear on. I advise you do an oil level check when returning from a ride. Do it per the manual.
checked oil after last ride per manual level full. check transmission light has always gone out as soon as stared and we always let motor warm up. This is first year starting in below 35-40 degrees and first time check transmission light stayed on. so assume if I let it warm up enough it will go out just checking to see if anyone else had same experience. thanks for the reply
Before going riding on colder days, I place a room heater with a fan fairly close to the engine to warm not only it, but the oil, the starter and the battery. I do this an hour prior to the ride. It makes startups a lot easier on all the aforementioned components.
