Check oil
manxman
I find not much difference checking the oil when it's hot or cold. About a 1/4 " low when cold. I have always checked oil before I start out.....2014 RT SE6
Relax. .!!
the 1330 ace engine in your RT 2014 does not use oil. Still check but not as often as the 998 v-twin. You can check it best when you get home from a ryde and not worry about checking before you leave...:thumbup::ohyea:
the 1330 ace engine in your RT 2014 does not use oil. Still check but not as often as the 998 v-twin. You can check it best when you get home from a ryde and not worry about checking before you leave...[emoji106]:ohyea:
They may not USE it, but there seem to be a bunch popping up that LOSE it!....[emoji38]
Sent from my SCH-I545 using Tapatalk
