JRWW
I have a 2010 RTS SE5 that has been sitting idle for about 3 months with a C Tek charger attached. Have removed front wheels and had new tyres fitted then removed rear wheel and had tyre fitted. Also drained coolant and replaced, during this time the key has not been in the ignition or had it turned on.
So went to start and it was showing in 1st gear with message in orange " Check DPS" with the handlebar symbol and would not start. So with a 13mm spanner put the bike back into neutral and the bike started.
Looked at Spydercodes and Check DPS has check battery connections. The battery connections are tight and I can't think of anything else.
Check codes and PO552 & PO551 came up on screen,
Spydercodes says Torque sensor shorted or Torque sensor open
Anyone have a suggestion or ideas?
