998cc Changed the vacuum hoses
little more checking...
Did you make sure they were both the same length...? Try starting the engine and letting it run and then spray some WD40 around the intake boots and see if the RPM's change so to rule out leaks there. Also did you clean the throttle body...? Then there have been times when the plug wires fail and give a similar stumble as well a plugs. Don't know how much has been done so hard to know what could be the issue. :thumbup:
had the bike at a dealer they changed injector in rear cyl,venturies replaced,spark plugs,wires,evap canistor and purge valve. problem fixed for about a 100 miles then started all over again
