cb radio headset
BuddaBelly
I just had dealer install cb radio on my RT. New can am headsets. I only grt to listen to radio when it wants me to.. If I unplug and plug headset back it it will work sometime. Any suggestions.
Other than faulty wiring, I have my BRP headset from day one, never had an issue.
radio plays, iPod, CB. Have you set up the head set in the audio section, you can set up how it integrates with the speakers, mix or mute for CB.
There is also a VOX setting for the CB/intercon, when you start to speak it will detect the sound in the mic and mute/mix the radio. This could be set to sensitive that's it picking up wind/ heavy breathing and muting your radio.
harry
It could be a bad headset wiring harness. I received a brand new one that was bad. I verified this by inserting the drivers headset in the passenger connection and vice versa. If you don't have a passenger headset this will be hard to verify. My wife was having this problem with hers and BRP replaced it after I told my dealer how I was able to isolate the problem.
Good Luck
