powerbyaj
Cargo Straps
Found a permanent way to hold down cargo without carrying bungee cords. Cannot take credit for the design but will take credit for the manufacturer on my first set. The site with the design http://www.s2straps.com/company.php
Had leftover web straps from the dog harness making days so I when to work making a demo set. 30 minutes later a starter set to test fit on the SpYder. My first set worked great on smaller items. My next set will accommodate large items. Also will create extension for the smaller set that clip-on.
The straps used the handle bolts for secured. I add a washer between the bolt and strap to keep the strap from ripping at the bolt.
The results mounted on the spider.
All pictures: http://photobucket.com/Can-AmSpyderCargoStraps
Mounting:
Item Strapped down 4 straps used:
Item strapped down 2 straps used:
Storing option for the straps:
Shealth method:
Mounting:
Shealth method:
