Can't retain last playlist using Iphone and dongle
Bob S
I have a 2015 RT Ltd. with the iphone/ipod dongle, I am using an old
Iphone 5 connected to the dongle for my music.
Here is my question. I have several playlists for my music.
Whenever I start the Spyder, it resorts back to the general
Music selection containing all of my songs and does not display
the last setting for a specific Playlist.
I, of course, keep forgetting to spend the time to go through the settings
back to my desired playlist every time I start up the Spyder and once
going you cannot do this unless you pull over to make the changes.
Is there a method so that it remembers where you left off?
It would be great if you could just speak into the system to ask for
a specific playlist or song, similar to what you can do with Siri on your
Iphone.
Thanks,
Bob S
None that I know of. This is a function of both the phone and the radio. The radio cannot store the last playlist and ask for it again.
Bob
I ONLY use my IPOD Classic on my '13 RTL with the BT Dongle, it always stays on the same playlist, I have at least 6 playlists on mine. I too don't like the have to stop to switch playlists, but have finally got the hang of it....
Is the iPhone a dedicated music player or do you use it as a phone as well. Often other applications, particularly stuff like iHeart & Pandora will cause the music player to reset.
If it is dedicated and you leave it plugged into your bike all the time, is it running down the phone's battery? When the iPhone reboots it will loose it's place in a playlist.
Also you said you were playing through a dongle. Is this a Bluetooth dongle? If so, the phone's music settings are completely independent of the byke.
I have an old dedicated iPod plugged into the connector in back and it remembers exactly where it was each time I start the byke.
I have a 2016 RT-S and use an iTouch plugged into the back and the BRP bluetooth dongle. When switched to ipod, it is always reverts to the general "play all" option verses the last playlist used. BUT you can switch playlists though the multi-switch without having to pull over. You just need good eyes to see which one is selected.
This Iphone is only used for music. I turn off the Dongle whenever I am finished riding or else the battery in the Dongle wears down. The Iphone also turns off when I shut down.
It is a bluetooth Dongle
Thanks for your help.
I am electronically challenged. I have recently purchased a 2015 RT-S. Can an adaptor be purchased so that the dongle in the trunk can be connected to my IPhone 8 fire wire connection? Can you then charge and access the audio stored on the phone? Thanks
Don’t know bout the FireWire but an Apple lighting to 30 pin adapter does work fine on my 8+ For charge & playlist. Yes defaults to general library @ every shut down. THANK YOU FINLESS- https://youtu.be/eqf6LOVsS2k additional note some menus not available in motion ***must be complete stop (most red lights not long enough to reasonable (safely)attempt parking lots before you get on road advisable. **also is dash does not get chance to do full boot up it tends to disable audio display in settings. Audio will still play but will have to go into audio control to skip songs & or reengage audio display in settings ** least on my 13. (Annoying ,just be aware)
