Cant open front trunk
Can't open front trunk on my 2009 RS. What would cause this?
over-filled frunk, or the cable could have come off the base of the ignition switch ….. the second one is almost as easy to fix as the first …… Mike :ohyea:
Try pushing down on top center (where latch post is)of frunk lid as you turn key:thumbup: hopefully simply overfilled or something hanging over the seal lip, causing the lid to sit lil tighter than normal
Hello, I had this happen to me as well. The problem turned out to be the cable itself. It had stretched enough so that it would not disengage the latch. I had to manually push the latch under the frunk lid with a flexible plastic rod.
