Canisterectomy Problems
kentompkins
For the second time I have sealed off the purge valve hose (I have not done the complete removal of the canister) hoping to not have the Spyder hesitate.
Last summer I had the problem bad; indeed it was in to my dealer in early Spring (March, I think) but they couldn't fix it. I tolerated it through the summer and, just before going to Gatlinburg, I sealed off the purge valve hose. I had no problem all the way down but, on the last day when the BRP service guy, was doing the update -- re-routing the hose to the front near the radiator and flashing the computer -- I went back to the stock arrangement so BRP would upgrade it.
On the way home, there was some slight hesitation but not at Interstate speeds so I didn't bother with it. The BRP "fix" was the second upgrade for me; my dealer had done the first earlier in the Spring. Theoretically, I should have been fine; others were but some weren't.
It has been bad recently; perhaps it's the heat? NJ has been excessively hot in the last few weeks (it's 91 and humid here now).
I'm going to Magog so decided I would re-do the canisterectomy to stop the hesitation on the trip. I did it last weekend but it is back again and is worse than it was if that is possible.
So, here's my question: is there some other aspect of the bike that is causing hesitation EVEN WITH the canisterectomy? It only does it between 4000-4500+ RPM which seems to make it too predictable to be carburetion. The same for any electrical problem getting spark to the plugs.
This is on a nearly stock Spyder. No juice box, filter, loud pipe, etc.
I'm thinking of unsealing the purge valve hose and hooking it back up to the canister again. After two upgrades, I don't think I should be having the problem which, if you think about, I've had for a year and a half.
ken tompkins
I would check the other end of the hose and make sure it's got a good seal and there are no cracks. Next thing I would check would be my plugs to make sure you're getting good spark.
Could also be a problem with your O2 sensor --- or Ambient air temp sensor.
Those 02 sensors can be kinda flaky.
This seems to be a reoccuring issue with many. However, the fixes all seem to vary.
Canisterectomy
spark plug wires or boot
spark plugs - some say irridium helps
2nd update
Bad O2 sensor
replacing O2 sensor with O2 eliminator
Juicebox or Fuel Pressure regulator
Gear Position Sensor
There was also a recent thread that talked about a couple valves or sensors that were the culprit but I cannot remember specifics.
Good Luck in getting yours fixed. I had the problem for 17K miles and could not figure it out. The motor blew and after they replaced it with a new case and internals I no longer have surging or hesitation anywhere in the RPM range.
