Hi. I beg your forbearance for hijacking a thread, but this one was the most recent of the ones I've looked at.
My 09 GS just had the check engine light and Check DPS message appear. Maneuvering in driveway at the time. Pulled codes using the high beam switch and got no current codes message, even though check engine and DPS message were showing. Battery less than a year old and showing 12.7 V. Terminals clean.
I put the VIN into the BRP recall page - says not under recall.
However, it does have a toe issue. Tires I just replaced were chewed up on outside, so definitely needs positive toe.
Questions...
1. Would this be enough to cause the DPS message?
2. If so, how does the ECM know this? Load on the DPS motor?
3. When I adjust the toe, will the ECM recognize this after some riding and clear the code?
4. Is there anything else besides a bad DPS unit that could be the issue (I read somewhere about a steering position sensor, I think)? Anything I can do in my garage?
I always appreciate the sharing of your knowledge and expertise.
Matt
