BaldEagle
Hello fellow SLovers. Bought new 2014 RTL and had dealer install the Can-Am Sena SM10 harness. The sending unit was mounted in the frunk "per factory recommendation". The battery in the sending unit would not hold a charge and was discharged after a couple of days even just parked in garage with ignition off. Had unit replaced and same thing with new one. :gaah:I charged unit with external charger till light turns blue indicating full charge but its dead in couple of days. Charging light comes on when ignition is on but never turns blue after riding. Asked the tech to check if battery was draining power by short. Claim harness is working properly. Does this unit need to be wired directly to the bike battery to maintain charge? Battery in helmet units hold charge for weeks. This is my first experience with bluetooth. My 2012 was wired to helmets. Any suggestions? Thanks. :doorag:
By the way, when the unit is fully charged, the system works fine and is paired with everything. When battery dies, I lose the pairing with the radio.
