Can Am GPS Mount
Steve67
Does the GPS mount in the Can Am Accessories website only fit the Garmin Zumo 660 or will it fit other models of Garmin GPS?
It looks to me any of the mounts that come with the Zumo motorcycle line of GPSs will bolt up to BRPs swivel or fixed mounting bracket. It looks like they all share the same 4 bolt pattern. Other lines of Garmin GPSs like the Nuvi car type will not fit. For that you would have to maybe go to a RAM system.
There are lots of options for mounting a GPS. If you want a temporary mount the Leader mount (SL supporter) is a good option. If you want to hardwire one (like I just did), then I recommend the Phoenix Gizmo mount sold on Ebay. You can mount any GPS, and still add a RAM mount for a coffee cup holder, etc. Both mount to the handlebar hub.
Since it doesn't seem like Garmin makes the Zumo 590 anymore, anyone know if the Zumo 590LM works with the BRP GPS mount????[h=1][/h]
If you look at the Spyder specs/options for the 2015 RT models BRP says the Zumo 590 is the GPS add-on for the RT and RT-S and is the OEM GPS for the RT Limited. I've been told by my dealer the mount and 590 will be release from back order on 12/19/14. In a phone call to Garmin a rep told me all 590s now manufactured come with lifetime maps.
