cam cover bolt torque spes
GS1
good evening all, does any one know the torque spec for the cam cover bolts or have a list of bolt torque specs for an 09 RS SE5, been trying to get them off the web:banghead: so I can finish up. Have ordered a cd put its going to take a little while. Any help greatly appreciated
I don't have an 09 manual. The 2013 manual says CAMSHAFT HOLDER SCREWS - Tightening Torque 11N•m (97 lbf•in). The 2010 manual says the same thing. Valve cover screws are 9 N•m (80 lbf•in).
Caution....
Thread up above has some interesting points on this. If using the lb/in scale there is a difference with the conversion as to inch lb's and foot pounds. I don't believe the valve cover bolts are tightened to 80 ft lb's. Don't have the manual handy to confirm the torque...:dontknow:
The valve cover bolts are not tightened to 80 lb-ft. The figures I quoted are verbatim from the service manuals. lbf-in equates to inch pounds which can be confirmed by converting 9 N-m to inch-pounds.
