Buying a used Spyder
Poasttown
When purchasing a used Spyder, or any vehicle, you are somewhat dependent on the seller to provide accurate information on the bike such as maintenance and/or problem history. Given the electronic monitoring capability of the Spyder is it possible for a dealer to "plug into" this system and provide the buyer with an accurate history of the bike?
Poasttown
Poasttown
Actually it gets better …. all you really need is the VIN & a helpful dealer …… But most spyders that are owner maintained won't have that info in the BRP record system...……...good luck …… Mike :ohyea:
The dealer can plug-in and tell you a bit about the owner's riding style, rpm, shifting, etc. Mike is right if the seller self-maintained, but if the seller purchased oil, filters, etc from the dealer and/or has good records, you can get some sense of maintenance.
Good luck.
Rob
