Bump skid - How much ground clearance do you lose?
It's not really the 'Ground Clearance' as such that's the issue, but because the leading edge of the bump skid projects forward from the 'chin' of the lower front panel, it's the significant reduction in the 'Approach Angle' that reduces your Spyder's ability to negotiate dips or drains & bumps etc square on.... :gaah:
You hafta slow enough to safely negotiate those types of obstacles at an angle, one front wheel at a time; and even doing that, you are still somewhat restricted over those things you could negotiate without hitting the 'protruding chin' of the bump skid & potentially damaging the things it's bolted/screwed to! :banghead: I know our Ozzie roads, drains, & verges might be a little different to those in your part of the World, but even so..... :p Do you really hafta ask me how I know of this issue?? :rolleyes:
If you get Baja Ron’s shock adjusters then none. You tighten them up to the original height. Easy peezee!
Aaand if you raise (or lower?!) your suspension/ride height, you'll mess up your wheel alignment by doing that!! :banghead:
