SpyderWolf
I am getting very close to buying the Black Rear Rim with Wheel Hub kit from BRP, part number 219400105 for my 2009 GS SE5.
What I am wondering is what, if any, other parts do I need to order for replacement at the same time I do this?
I have a copy of the installation instructions and it states the parts to be replaced are Rim and Hub Kit (219400221), 2 Ball Bearings (293350067), 1 Seal (293200094), 5 M10X35 Bolts (207503544), 5 M10 Nuts (233101414), and the Cotter Pin (250400047). For that reason I am assuming these are the parts that come with the kit.
When I look at the parts schematic on BRP's online catalog, I see additional components that are not included in the above list. The following link will get you to the parts section, then you need to drill down on 2009 - SE5 - 08 Drive System, Rear: http://parts.spyder.brp.com/Index.a...tbamk04e1&catalog_id=0&language_id=1&siteid=1
I am specifically looking at a couple of O-Rings (293300131) and (293300124), then the Damper (705500736), some Loctite (293800060), the Double Row Bearing for the Sprocket (293350065), Circlip (293370053), and a final Seal for the Sprocket (293200094).
It appears BRP wants me to reuse these parts, but I am wondering what your thoughts are on whether any of these should be reused or replaced.
