BRP hitch removal
SPYD1
I want to remove the hitch from my 2009 RS. The question is:
Do you just take the cotter pin and nut off and slide the axel out and slide the hitch back off?
And all is well?
That's it
And all is well?
That is it.... you will need to put a cotter pin back on the nut on the bike's axel and if you have them the two plastic black caps that was on it before the hitch install.
Bob
And all is well?
I didn't think BRP made a hitch for the RS. I know the BRP hitch for the RT has a rod that goes through the axle. ON my old GS I did what you indicated. I had the hitch made in Canada. If the belt moves, which it is likely to do, then you must re-calibrate the belt.
Thanks. Yes, the RT hitch fits the RS.
Dick, still looking for you to let me know when visiting your daughter.
The hitch is a tight fit on the frame so it takes a bit to get it off and back on. Once the long bolt is out ry to wiggle left and right at the same time as you pull/push for removal/install.
Good luck
