Hi all,
Well I bought a new (old stock) BRP hitch which had the 9 pin control module which I didn't use (used Show Chrome harness instead) all is well electrically. I have a 2015 RTL and could not get the hitch to slide onto the swingarms. I noticed there are some what look like thin poly shims/protectors that are glued to the inside contacting surfaces of the hitch. I tried grease and silicone and could not get the hitch to slide over the swingarms no matter how hard I tried. I finally removed the upper and lower shims and bingo, slides right on. However without tightening the thru bolt, I have about a 1/2 to 3/4 inches of slop on the ball end. Will just torqing the bolt be OK? I thought all BRP hitches would work on any year rig. Anyone else have this issue? Thanks.
