agedbikeman
End of August last year I reported a broken steering lock due to attemped theft of my RT. I went to a dealer who had a ingnition switch assembly over from a swapout just to look at it , looking at it there was no way the actual lock itself would break it's so strong. I decided to investigate, all that had happened is, looking at the first picture of the top steering support, the lock pushes a pin out on one side or the other of the square block at the top, the pin only protrudes about 5mm to jam against the side of the block, the pin had scored a groove across the top of the block, photo 2. As there is plenty of room I Drilled and tapped the block and screwed an aluminium U shaped plate across the block, photo3. This works very well and should the same thing happen again, just replace the plate.
New steering support 80 dollars, 2 days work. My method less than 1 dollar 2 hours work. NO CONTEST
