Broken Antenna on 2014 RTL - what size socket will take off without removing tupperware?
I have a 2014 RTL that the antenna broke off right at the tupperware. Does anyone know what size socket the will take that off without having to tear the tupperware off? I can't get a wrench down in there to get to it, but if I knew the size of the base of the antenna where it screws onto the bracket, I could go buy a deepwell socket to remove it.
As I recall, I used a 9mm deepwell socket and a pair of vice grips!
The antenna threads are glued on with the yellow stuff, so it takes a bit of muscle to break it loose!
