brake shoes
HenryA
Nice afternoon to put on the new Baja Ron brake pads. The oem pads have a pair
of wire clips on them and the new pads do not. So started to remove the clips
and you know what happened next, they disappeared in the shop somewhere.
I see the oem pads come with these clips but I really don't want to spend 80
bucks for a set of 4 pads I don't use. Anyone been through this before and found
a solution
Well after the third look I found both spring clips so be aware if you intend
to change the front pads to have some sort of locking pliers handy to keep
the little devils from taking a hike across your shop. Putting them back on
seems much easier than coming off. Looking forward to the extra stopping
power
Thanks for the heads up. I wonder if the rear pads have the same clip? I've got a set of Ron's rear brake pads to put on and I'll watch for this.
Yes the rear uses the same clips. I can speak from experience these little rascals fly like they have wings.
It would be nice if the EBC pads came with these clips. (actually, they do... I take them out and HORDE them before I ship the pads! They bring a pretty penny when the customer loses theirs!) :roflblack:
Sorry, couldn't resist!
The OEM springs are reusable but they are crafty little buggers. You've got to keep your eye on them!
Old shop trick...
Throw a large shop towel over the work, or work inside a large ziploc bag when removing springs. They won't fly as far. Of course if you enjoy the thrill of the hunt, you can let them fly. :)
If you can schedule this job at the same time that you're having an MRI done; that machine might just be able to catch those crafty little buggers! :thumbup:
